Hey all,
I've just been looking around, making a futile attempt to track down one of the fabled Griffith hubs. No dice so far, but I did stumble across this potential alternative. Has anyone worked with this device before?
http://sewelldirect.com/usbhubmini2port_specs.asp
More than anything I'm trying to find a hub that will place a minimum of structural strain on the Pandora's port when it's not resting on a table or something similar, such as when I would be holding it while on the go, so I'm mainly considering port-powered lightweight hubs with longer cables (can be placed in a pocket) or port-powered hyper-compact ones with at least two ports (hugs close to the Pandora's form, providing maximum structural support). I'm thinking this one may fit the latter criteria almost as well as the Griffin one would, but I'm still looking in case there's something better lurking around someplace...
EDIT: Oh, and while I have run across a few that might work quite well while taped to the Pandora's lid, I'd rather not take that sort of approach if I can help it. Then again, maybe there's some kind of velcro-style solution that'd work well...
Cheers~
