Just a quick info:
If your TV can do both NTSC and PAL, you should use different settings for different emulators and games.
For example, if you run a 60Hz game on the Pandora and use TV Out with PAL, TV Output will stutter a bit.
So if you plan to play emulators with NTSC or Japanese games, switch TV Out to NTSC.
If you plan to play emulators with PAL games, switch TV Out to PAL.
Amiga and C64 usually run with 50Hz, so use PAL here for smooth scrolling.
As the Pandora usually runs with 60Hz, NTSC will run most normal games without stuttering.
