notaz
Certified Guru
No, but i haven't really looked for it, I'm finalizing some cd emulation related changes right now.@Notaz : thanks. Did you find the problem with TV Out on Picodrive 1.85 ?
What makes you think so? By default, I think, it's set to S-Video so if you're using composite, you'll need to change that in the settings.i suspect my tv-out cable isnt working properly what should i do?
yes i know this, its only after a game is launched that i get a short period of distortion then blackness, in some cases followed by more distortion. i'm using the cable through my projector, the only other tv in the house is bolted to the kitchen wall so no chance of plugging a cable in there. Tonight i will try and video the cable behaviour and post it here so you can better see what i mean.It can be normal to only see a black screen until the game itself is launched.
No, i use MameEX for all my maiming needs. I dont use the romset required for PanMame. Tried switiching display on the projector as you describe too, with no variation in results.Have you tried PanMame? - That requires HW layer activated too, you'll see the selection screen on the Pandora and nothing until the game is running on the TV-Out. If you get the same results with that your best bet is probably to get access to another display to confirm whether you're generating a HW layer signal at all.
I have the same problem having tried on three television sets. Still trying to figure out what the problem may be.yes i know this, its only after a game is launched that i get a short period of distortion then blackness, in some cases followed by more distortion. i'm using the cable through my projector, the only other tv in the house is bolted to the kitchen wall so no chance of plugging a cable in there. Tonight i will try and video the cable behaviour and post it here so you can better see what i mean.It can be normal to only see a black screen until the game itself is launched.
Do you get sound even if no picture?I have the same problem having tried on three television sets. Still trying to figure out what the problem may be.
