Gp2x Thunder Power Pack (new 3600mah Battery)
cowai posted on Mar 5 2007 at 02:04 PM said:
Explain a little?
I will get a picture. Edit: here.
Pry out the battery clip, (must replace with something else or cut down middle and separate). Go Large.
Connect in series: Go Large A. Go Large B.
Side view.
If you want to use 2-cells just add a jumper or loop to reconnect the battery tray and remove the extra cell holder.
cowai posted on Mar 5 2007 at 09:58 PM said:
Hey, Cool! So have you tested the runtime with this?
Maybe while I am gone today, I still haven't replaced the battery clips with anything useful.
Edit: Have done: 3 Cell battery test thread
Quick results: 6:17mins @200mhz, 5:40mins @250mhz. Not bad, not bad at all. (not as long as the monster though, well we don't know yet do we ;) )
I'll buy the thunder pack if it's not to expensive. Hopefully that's not going to be the actual size when it's released.
You can buy it at hardcore-gamer.net right now. Any other website that sells them?
EDIT: Never mind I found it.
