mali
^ According to this, ground and microphone contact are switched compared to the Pandora's pinout:
http://pinouts.ru/PortableDevices/iphone_headphone_pinout.shtml
/copydir said:I just want to state the obvious...
you are aware it is a wheel? it moves from side to side over 5 time to fully turn it up or down.
You say it "hardly does anything" so it does something maby you just need to turn it a few more times
Sorry lolBosbeetle said:/copydir said:I just want to state the obvious...
Yes I couldn't push further, I put quite a bit of force on it. And I know how a volume wheel works
/copydir said:Sorry lolBosbeetle said:/copydir said:I just want to state the obvious...
It is an analogue attenuator. so the headphone amp and speaker output are passing through it.
So it is "working" It sounds like the resistor pad in it is shot.
/copydir said:It is an analogue attenuator. so the headphone amp and speaker output are passing through it.
tsh said:/copydir said:It is an analogue attenuator. so the headphone amp and speaker output are passing through it.
Actually, from my recollection of the data sheet that someone linked to last year, this is a high quality amp with an analogue? attenuator built in - the control is a single pin to adjust the gain of both channels (which means the signal does not pass through the external wheel, improves L/R balance, and reduces crackling whilst adjusting the fader). Broken probably means the input pin is at supply rail rather than in the correct range.
