Ranma13 posted on Jul 18 2006 at 09:55 AM said:
Are you just plain stupid, or do you like contradicting yourself? You just stated the EXACT reason why so-called 'identical' units have 'drastic differences' in performance.
You apparently aren't reading very well or carefully. My very first response to you was, to recognize and accept the issue of "identical units having drastic differences in performance". See it here:
gamefan999 posted on Jul 17 2006 at 09:04 AM said:
So the question is better addressed as, did I get a "common" chip, or a "super" chip?... Still, as you are saying, I bought a chip rated at 200Mhz, so as long as I get *that* performance, I am not allowed to complain. But I can't help but feel cheated when I hear some units can OC stably (?) at 300Mhz.
If you think that accepting "simple differences in silicone and manufacturing" as an excuse for tolerating a wide range of performance is ok, then that is your business. I personally think that manufacturers can and should provide more consistency in their products. It has been implied in this thread, the manufacturers are aware of the issues of varying performance, and simply chose to overlook them. That is my beef, nothing more. I know you are going to respond with, "/whines/ But you're not supposed to get anything over 200Mhz, so you've already gotten what you paid for!" or something like that. But if you did say that, you would still be missing my point of not getting one of the sturdy units that get discussed in the forums. You must certainly work as a corporate liason for engineering-to-marketing (or ought to), what with your penchant for absolutes coupled with your whiny devotion to the letter of the label. Give us all a break! Anybody who buys anything expects to push it past its limits. Like I said, almost all products are designed with that kind of use in mind, if you don't know that, then *you* are being naive. Is it a crime to want stable 280Mhz instead of 233Mhz?
Finally, I find it wonderfully ironic that, for your last, persuasive analogy, you condescend to use a (gasp!) physical object to describe a digital process!! What on earth has gotten into you?!? 8^D
If I *was* going to buy bolts that I intended to use for up to 200 pounds of stress, I sure as hell wouldn't "go online and find out that these bolts are rated only at 100 pounds of torque maximum" AFTER I bought them!!! Wouldn't it seem logical to you to do such research BEFORE making a purchase? In which case, I wouldn't have *reason* to complain about a "faulty" 150 pound bolt, because I would have purchased the correctly rated hardware in the first place.
One last point...
Either way, this topic has gone way off course.
No, it hasn't: the OP said,
Xavier LaRue posted on Jul 16 2006 at 01:07 AM said:
The only thing special I've seen is that I can't overclock over 250 [ at 260 it frozen, but I presume that is normal sinece we're already at1.25x the normal speed ]
wipeout2000 posted on Jul 16 2006 at 01:32 AM said:
Yea u should try to return it. Mine overclocks to about 280 stably. That way you can get rid of the led problem and hopefully get one that overclocks better.
Congratulations on your stamina if you have read this far, though I don't suppose you have! And please, don't respond. Your self-congratulatory and weakly repetitive arguing ability bores me. I love a good conversation, debate, or argument, and you can't provide one.
