My battery died while my GP2X was plugged in and i was transfering files onto it. Now my memory card isn't responding when i try to open it on my PC, but all my files still run fine on my gp2x.
help?
help?
Sounds like it 'might' be a bad FAT table, if you have any PC disk repair tools try running them on it. Failing that you might fix it with a reformat...
I put it in my dvd recorder which had a sd reader built-in and formatted it from there .
Try that, or maybe you have a camera or a pda which uses SD cards, then try formatting from one of those devices.
