Low Battery Indicator!
ZiUL
Lol! Already got an idea!
How about a dual-color led replacing the actual gp32 power led... so when the battery is low the led will change colors...
Think Think :lol:
Vimacs
Don't be evil!
Germany
ehm guy, we have allready a much better sulution, you can add a a single wire inside the gp from the power to the µc and you can read the battery level by software
ZiUL
Good to know! Thanks!
but anyway this still a good option when you're running a game or other program that doesn't display the battery level :)
0-bake
i don't see the use of a software battery-tester.
if i play i game and suddenly the power goes off, i really would've liked a led to show me "let's make a savestate!"
elektrocution
Norway
www.systm.no
Vimacs posted on Sep 29 2004 at 02:09 PM said:
whats about the game says by itself in a nice little popup "batetry is low" and saves by itself?
that would be even better, but as a different savename tho, not overwriting whatever you had saved before. imagine you just died or something, the battery went out and it saved over your previous savegame :(
0-bake
could this be done by the firmaware? i think, if yes, the hole 8MB memory must be saved...
and otherwise, every emu-author must implement this and for homebrew games, as well.
a different colored led would be muuuch easier, like at the gba/sp.
V3X
Dance Pac-man. DANCE!!!!
sunbury, victoria, australia
yeah, that wouldnt be good, but it would be if when u choose to save u quikly save a file.
like:
file0.sav
file1.sav
file2.sav
file3 ect.
mabey sumthing like that? :)
Gruntfuggly
Mostly Harmless
Brighton, UK
www.zaonce.com
This concept is pretty good - you could have a firmware monitor running on an interrupt which would dump the memory at the appropriate point. It could check every few seconds, and shouldn't have any impact on anything currently running. You could wire the battery to the ext port and read the voltage that way. The only worry would be if it detected the low battery and started saving, but then the power went off while writing to the SMC...
Protoss
Houston, Texas
eatsleepgame.com
I am still going for the LED thing...Just alot more convienient, so you could do a quick glance and see if your battery was dieing. Anyone gotta chance to try this? Or planning on trying this on their GP? I'd love for my GP to be modded with a battery monitor LED, or maybe add a blue or green LED that would overtake the red one :ph34r:
