Small Problem With Pacrom
mechanori
When using Pacrom through either Spiv's or Aqua's MultiFW, there are blinking vertical lines that are very annoying and distracting. Is this a problem with my GP32?
As far as I can tell, it's only in Pacrom. Is there some sort of testing program that changes colors or something, just so I can make sure?
i think sum1 had this problem a while back, there is definately nothing wrong with your GP32 if it is only in Pacrom
Im afraid i cannot recall the solution tho
uhm, it's not a particular problem with pacrom i think..
if it's just that the screen is flickering, then i guess you'll have to live with it (have this too)
but if its really bars with different colors that are blinking, you're fucked o.o
can you make shots with a camera?
i think someone said its to do with the Low CPU speed that PAcrom runs at..
Hmmm.... You can see them in fGB32 too.
Is this a GP32 specific problem? I ordered it from GBAx.com. It also has a green pixel, which flickers on and off. You can only see it when the screen is a dark color, so I was just going to deal with it, but if this is a problem also...
