Guyfawkes
Certified Idiot :)
I have been doing some tests to see why the GP2X USB connection wont work. I think I may have found a solution but cant figure out why its causing it.
At first my PC wouldnt recognise the GP2X at all. Tried three different USB cables and none worked. But plugging it into a USB 1 port would give the Windows message that the device will work better if plugged into a USB 2 port, so it did seem to work to some extent.
What I done next was remove my Card Reader which was connected to a different USB port to what I was using to connect to the GP2X. I then connected the GP2X on a USB 1 port and it worked first time!
I then reconnected the Card Reader and tried again and the GP2X still worked. I also tried connecting the GP2X to different USB ports and a USB 2 port and all worked perfectly.
Not sure if or why my card reader was causing the problem but doing the above fixed it. It might be worth trying to remove all your USB devices and connecting the GP2X and see if it can be recognised. If it does work then reconnecting your other devices should be fine after that.
Let me know if it works for you or not. I posted this on my own forums also which you can read here.
