Hello,
Just got my Pandora today and was working on getting all PSX files that i ripped into the correct format (which is .bin I assume?
Anyways, let me explain my situation with my SD cards.
I have 1 Lexar Pro SDHC class 10 16GB card (normally I will use this to install android gingerbread) in FAT32 (standard) --> slots don't matter, i tried both.
and 1 Lexar Pro SDXC class 10 128GB card (Here will come all my roms etc.) in ExFAT (there were only 2 options for formatting: exfat and NTFS so I chose exfat) --> slots don't matter, i tried both
Here's the deal: I installed PNDMANAGER onto the 128GB and that seems to load but nothing I install on the card seems to work!
However I get 2 options when I want to install:
- Save to Pandora (name of 128GB card)
- Save to my other card (16GB one)
When I select the first option, it doesn't really seem to install correctly (no appdata etc.) and when I click on the start icon on desktop, my Pandora hangs.
All works pretty good on the other SD card... Can anyone advise? :S
Thanks!
Stiino0
Thanks!
Stiino0
