Exophase
Nothing good will ever come of Exophase.
Although 5% for 15 minutes still seems like a little much. That would mean I'd get about 5 hours game time, and my Pandora definately lasted longer than that before. But I guess that's just natural battery degredation over time?
Disregarding the wrong percentage, this methodology isn't really correct.. voltage vs capacity on Lithium Polymer batteries is very non-linear. See the graphs on this page:
http://www.ibt-power...um-Po-tech.html
Capacity vs time, on the other hand, should be a lot closer to linear, at least away from the extremes, since you'd be drawing about the same power. There'd probably still be some second order effects as the efficiency of the power regulators might change slightly depending on how close the input voltage is to their output voltages, but I wouldn't expect it to vary nearly as much and certainly not in a way that cancels out the voltage vs capacity non-linearity. In other words, you shouldn't look at voltage drop between two points and try to linearly extrapolate what your battery life will be.
This could be a useful tool to monitor what your battery is reporting:
http://boards.openpa...ra-system-info/
Maybe you could add a logging feature so we can see the aforementioned curves
