Gp2x Crashes At Startup When Using Battery
fkey
Hello,
I do have a problem with my Gp2x F-100 Mk2 :
Whenever I boot it with NiMH battery (2500) It crashes at startup like if the battery where empty (screen becomes unstable and white).
I tried with other battery fully loaded but I still got the same problem.
This doesn't occur with the AC/DC sector adapter.
I really took care of my gp2x and I really don't know what is happening to it.
Has anyone had the same problem as me ?
Does someone know how to fix it ?
Thanks for your help.
I had this problem. Even though my batteries appeared fully charged, there was something wrong with them.
Go buy some new ones and try again.
battery issue. either not enough amps or not fully charged. new batteries with a higher amperage should work fine.
had the same issue with some cheap batteries, name brands worked fine.
