So last night I picked up an AC adaptor for my GP2X (the Radio Shack Digital Camera plug) and happily used it to play a few hours of Sam and Max Hit the Road. Unfortunately, like the moron I am, I had not realised that you are not supposed to plug in an AC adaptor when you've got batteries in your handheld. I tried to use battery power only to discover that my GP2X would glow the little power light on the bottom left, but not actually turn on, when using only batteries.
I searched the forums for a bit to see if anyone else had encountered this problem and discovered one post, which talked about how you could disassemble your handheld and lift a metal plate in a 'little black box' to make the GP2X work with batteries again. There was a diagram attached at one point, but said diagram has long since gone the way of all flesh. When I opened up my handheld, I couldn't figure out what I was supposed to do to make it work with batteries again.
Does anyone have any idea where I could find the picture that would show me how to make the required fix? I need to be able to use my GP2X where there isn't AC power available. :-/
In case it matters, my unit is a MK II.
Thanks in advance!
Chris
Thanks in advance!
Chris
