Not to run the cradle, no... and to make matters worse, it needs a 3 amp slupply, much more than your average 'home' muti-way adaptor can provide....zacaj said:Couldnt you just plug the regular power adapter into the GP2X?
Echomote said:QUOTE
Although the board will run via batteries it is recommended you use a PSU with it since it will be at home anyway, rather uneconomical to waste batteries!
So why can't a GP2X power adapter be used?
Cradle needs 5V, GP2X gives out 3.3V.
