asimov-solensan
Very Active Member
- Joined
- Jan 8, 2010
- Messages
- 741
Hello,
I have got a DVB-T server at home. I created a web interface that initializes the receiver and then mumudvb generates a streaming link that can be opened with VLC or similar.
This was nice in older firefox versions because the link was opened with the vlc-plugin and it was seamless. In android also works because firefox just allows you to choose a program (kodi for instance reads the stream without problem).
But newer versions of firefox are a PITA and even if I choose a program to open the stream it tries to download a file (of course of infinite length) and the open it in the selected program.
Of course in pandora none of those methods works. I can simply copy the link in VLC. But, hell, I'm an engineer, it's in my DNA to overcomplicate things to unnecessary extents.
So I was thinking how could be a way to do an interface that does some web requests and the calls VLC (is it possible to call pnd_run vlc and then open the link?). I would like to find a way of doing this as portable as possible but Pandora is my main concern right now.
For instance I have got this solved in my computer with an Xdialog script, but I checked that this isn't available on Pandora. And I want it to have some sort of graphic interface.
Is there any web browser that allows to script "Open with ..." options? That would also solve my problem.
Regards.
Regards.
