It appears Notaz has hit on something interesting, and a possible solution. I turned my Pandy off at 11:15 PM EST last night while wifi was on (and connected) and battery level was at 75%. When I turned it back on this AM at 8:15 AM the battery drain was, lo and behold, a wonderful thing, battery level had gone done only 1%. That's 1% in 9 hours, not 1% per hour as I had been experiencing.
Now the only further testing is to 1) turn off with wifi on and NOT connected, also 2) turn off with wifi off (in case it's the new firmware that caused the change. I'll do these tests to see if further isolation / diagnosis can be determined. As it stands it's a very good thing though as I can turn off my Pandy and not worry about battery drain by just insuring that wifi is on when I power down.
Not sure what train of thought you followed, I'd assume something you saw while tweaking the wifi? Nice find.
Twiitcher
"I had NOTHING to do with it"
Twiitcher
