Wah Help Me While I Still Have Battery Left!!
DReffects
hi folks,
about 10 minutes ago i've started the firmware upgrade from 1.4 to 2.0
ive formatted my 2gb sd card in fat32, copied all the files, booted up my gp2x, the initial firmware upgrade screen was shown.
then after a while the green loading screen showed up with the new firmware-version.
well - after 10 minutes i still have this loading-screen and i am getting VERY worried as the official site says this takes only 3 minutes.
any suggestions? should i switch of or remove the sd?
THANKS!!
dr
DReffects posted on Aug 19 2006 at 08:52 PM said:
hi folks,
THANKS!!
dr
Turn off, then hold Start and Select when turning it on.
Restart you GP2x holding start+select. I think it's those two anyway. There is no danger of restarting at th egreen loading screen. Well, not to the firmware anyway.
