I don't seem to be able to get the USB port to work at all on the GP2X,
at the moment I'm only trying to access the SD card as storage from
a Linux (Slackware) PC, but I would like to use USB networking as well.
I'm selecting Setting->USB->SD Memory Card which gives the
"USB connected" message, but the PC sees nothing (dmesg
reports nothing and there is nothing new visible from lsusb) all
these ports are known to work with other USB storage devices.
I've tried another Linux (RH FC5) box , a Windows PC (all these ports
are known to work with other USB storage devices), a different cable
and the latest firmware upgrade without success, have I missed
something obvious or have I got bad H/W (I've only had the unit
a couple of weeks) ?
dmesg on the GP2x reports (this is turning on the USB and then doing
a disconnect after a few mins):
[there are a lot of these ecc error messages]
**>>ecc error unfixed on chunk 1573:0
**>>ecc error unfixed on chunk 1573:1
**>>Block 49 marked for retirement
**>>ecc error unfixed on chunk 1574:0
**>>ecc error unfixed on chunk 1574:1
net2272: Set 2272 bus timing
net2272: PLX NET2272 USB Peripheral Controller
net2272: irq 222, mapped mem c280c000, chip rev 0011
net2272: running in 16-bit, byte normal bus mode
net2272: version: 2006 April 5, v3
g_file_storage net2272: GP2X Storage Driver, version: 05 June 2004
g_file_storage net2272: Number of LUNs=1
g_file_storage net2272-lun0: ro=0, file: /dev/mmcsd/disc0/disc
net2272: g_file_storage ready
**>>ecc error unfixed on chunk 12729:0
**>>ecc error unfixed on chunk 12729:1
**>>Block 397 marked for retirement
fsg_unbind
net2272: unregistered driver 'g_file_storage'
remove........
net2272: unbind
MSDOS FS: IO charset utf8
USB SUSPEND MODE
remove........
net2272: unbind
fclk 100MHZ
fclk 100MHZ
Thanks,
Bernard
fsg_unbind
remove........
net2272: unbind
USB SUSPEND MODE
remove........
net2272: unbind
fclk 100MHZ
fclk 100MHZ
Thanks,
Bernard
