Hello
Ok , dumpgfx don't work on my pc .
So i must do it manually
This is what i did :
I have ex. Garou.zip 77 Mb
i did this methode
Quicker method (requires WinZip to be installed):
1. Open Notepad into a blank file
2. "Save As..." the first romname, e.g. 096-c1.bin. Repeat, simply changing the number for each cx file. edit: remember to select "All files" in the save dialogue or it will save as .txt
3. In Explorer, highlight all the new 0kb romfiles and drag them onto the rom zip. WinZip should open up a dialog box giving you the option to replace the existing files in the archive.
When i am done i get a zip file from 14 Mb .
But what must i do whit the rest . If i understand i must have 2 files , the zip rom and the .gfx file . But how do i get that .gfx file ??
Could somebody help plz
i did this methode
