diligentcircle
Well-Known Member
So, for the past week or so, I've been working on porting Project: Starfighter to the Pandora.
I am pleased to say that I'm almost done. I have successfully reduced the game's original resolution of 800x600 to 800x480, with some invaluable assistance from the most active maintainer of Project: Starfighter on Sourceforge. I've also changed the controls to better suit the Pandora. Here is what I've got so far:
http://www.mediafire...3jce0xccez6x4kw
BUT, I've hit a roadblock. I was able to successfully compile the source with the C/C++ Development Tools PND, but whenever I try to run it, I get this error, which doesn't show up on a Linux PC, after the intro screen:
Anyone see the problem or have any ideas why this error would show up on the Pandora, but not on a Linux PC?
To compile and run, just download the C/C++ Development Tools PND (if you don't have it), edit the makefile to point to an SD card or USB drive you have (it's set to SD_APPS, since I have an SD card with that label; change SD_APPS to an SD card or USB drive you have), run the PND, go to the source directory, make, make install.
I tried to use Valgrind, which turned up in a search of this error, but for the life of me I can't figure out how to compile it on the Pandora. The docs are all over the place and point to non-existent files, while doing "make" causes it to tell me that there's no makefile, and I see no configure script anywhere. There isn't a file called "Makefile" or "makefile", but there are files called "Makefile.am" and "Makefile.in". I'm guessing the version of make in the PND is old or something? I'm not very familiar with make.
*** glibc detected *** ./starfighter: corrupted double-linked list: [hexadecimal number, memory address I assume] ***
Aborted
