Barnaby
Hi all, I've been away from the Pandora scene for a while due to having a faulty LCD cable in my Pandora. It'll be repaired soon so I've come back to the forums, flashed the OS to SuperZaxxon and been reading all the juciy updates and improvements since I last properly used my Pandora almost half a year ago. I have to say I'm wowed by a lot of the new stuff and the latest OS is great. Just saw that we can run Android through an app now (I think it's through a PND?) but I had a few questions before I try it. I'm quite excited as the only Android device I have is an HTC Wildfire S, which is too slow to run most applications.
Firstly, do I need to run Android off an empty SD card or can I just stick it on my current Primary card? As far as I can tell it just seems to be a PND that you run, and it'll load up Android - is that correct, or do I have to install it to the NAND as an alternate OS?
I have an original CC 256MB Pandora too, so I was wondering what would and wouldn't work on the device. I saw someone say they ran Mass Effect: Infiltrator which made my heart skip a beat as I'm a huge Mass Effect fan - but it seems it will only work on a 512MB 1GHz unit, which saddens me. Other games I'm interested in trying are Angry Birds: Space and Peggle (yes, my phone is too slow to run Angry Birds properly...). I don't want to buy something that someone says works, only to find out they had a 1GHz unit so it won't work on mine.
Lastly, to an Android newbie like me, once I have it set up is there anything that I should know, or something that's really a must have on the device?
