Problem with Linphone (Split from other topic)
sukhi2011
Birmingham
I'm trying to use linphone but when i type my own landline no. it just says call ended,why isn't calling the no. i'm dialing.
I've split this from the Pandora General topic about whether Skype is available on the Pandora, and moved it to the Support section. I believe the question will get the attention required here.
Hi sukhiextreme,
Your unlikely to get too far with Linphone at present I'm afraid to say. Consider it more a proof of future concept at this stage. Both Ekiga (crashes) and Linphone (has ALSA and MIC and Bluetooth issues) need further work before they will offer VoIP via SIP protocols/accounts.
Linphone requires also that you have enabled the internal MIC of the Pandora (which I know from prior posts of yours that you HAVE done so for use in Audacious), and it has been shown by mcobit to work with webcams to display picture, even though Sebt3 built his Linphone port with Webcam support supposedly disabled. However no-one has managed more than a test call to themselves (Alerino) or to anything beyond a test-call echo room service, in which they can hear the audio coming to them but without the MIC enabled cannot speak back.
I think in both cases of Ekiga and Linphone, better results were had in Debian extends, or perhaps Pandebian, than in the XFCE default OS.
In XFCE we have to wait aswell for the next OS release Yars, in which better Bluetooth handling is intended to be included, as currently you cannot have more than one audio stream using BT, unless you make a modification to the .asoundrc file hidden in your home directory, as discovered by Custom Processing Ultimate here http://www.gp32x.de...post__p__947023 which is part of the actual thread about the port of Linphone when it was released by Sebt3.
These other threads all mention Linphone or Ekiga but all ultimately lead to the conclusion that we dont have a fully working VoIP solution on the Pandora yet, so you will have to wait or figure it out yourself somehow (which doesn't mean being told to OC to 1337mhz either ;) )
Linphone thread
http://www.gp32x.de...58289-linphone/
Ekiga
http://www.gp32x.de...ic/57263-ekiga/
Voice Chatting
http://boards.openpa...__fromsearch__1
iPhone 4 vs Pandora
VoIP
Feature requests for HF6
Skype on Pandora
best of luck :)
Great explanation!
Now we have something to copy&paste into every now topic about voip. :)
It's asking for sip address or phone no. what do you write their,well i typed in a no. which was my own,it doesn't go through,why is that happening,threads don't explain that,when you dial a no. it just says call ended,when i press green button.
FWIW, this is my current project. The Pandora's audio setup is with a (play only) dmix on top of hw:0,0 and then the
microphone(s) (built-in and via speaker jack) on hw:0,1. Linphone seems befuddled by this, not fatally, but things just aren't lining up perfectly. I've just enhanced the "alsadev" config parameter so Linphone can know about two distinct ALSA devices. I'm hoping that can simplify some ALSA variables and let me get true calling working, after which I can circle back and get the audio output to go via dmix while still getting microphone input from hw:0,1.
linphone doesn't let you specify more than one hardware ALSA device. So for that config entry I burst "dev1|dev2|..." and create dev1, dev2, .... This lets me have an explicit hw:0,0 for audio and ring, and hw:0,1 for the microphone. It still doesn't work, and hell if I could make its debugging system work, so I just put fprintf(stderr, ...)'s into the code. It looks like the number of channels parameter for the capture is what's bombing. I'll keep you posted.
Yes, looks like the capture device, hw:0,1 will not accept # of channels==1. That's pretty weird, seeing as it's not a stereo microphone. I guess there's some confusion, because it looks like the internal microphone is assigned to left and the one on the headphone plug is right (or vice versa, but you get the idea). I'm going to tweak linphone to look at the HW channels via ALSA and adjust its idea of # channels. But this unusual style of capture hardware (as represented in ALSA) is probably not going to play well with most Linux programs....
Ok thanks.
One thing: i installed Linphone under Slackware, but didn't have this problem, config went fine.
I can phone a call, but big problem: i hear nothing, and neither the ppl i call :/.
Ekiga had registration problems with my SIP provider.
The one who worked "best" was Twinkle. I can speak, but i hear nothing.
Under PanDebian, Twinkle worked perfectly:
About ALSA, i was told by ED and Notaz that maybe a custom .asoundrc (or system-wide /etc/asound.conf) can create/tweak devices. I didn't succeeded yet, but this info may help you...
[ALSA custom device]
Yes, I slowly caught up with those great minds! :->
I realized hacking the C was silly, and created imic/xmic devices using ALSA's "route" plugin to pick off L or R from
the hw:0,1 and then offer a mono device. This let my call fire up and things look good, although I have to rebuild with all the debug noise removed and then see if I can get a real, full-duplex call running. As always, I'll keep this topic updated.
BTW, if you know how to create an ALSA playback device. I miss it in Slackware. I just see record controls.
Woohoo! Just left a voicemail for myself and it all sounds good. Here's what I added to /etc/asound.conf:
# Pick Left or Right off the capture audio
# of the Pandora, offer a mono sound source
# of that channel.
pcm.imic {
type route
slave {
pcm "hw:0,1"
channels 2
ttable {
0.0 = 1
pcm.xmic {
type route
slave {
pcm "hw:0,1"
channels 2
ttable {
0.1 = 1
With that, I added the following line to .linphonerc:
alsadev=imic
(right above playback_dev, though I doubt position matters)
Then start up linphone and in config/media choose "imic" as your capture device. You should
then be in business.
If you're using a four-conductor headset on the front headphone jack, change to use "xmic" instead
of "imic".
Note that playback/ringer can just use omap3pandora, the default value linphone will select.
Thank you dude, you ROCK !
Now i have working VOIP for my Slackware !!!!!!!!!!!!!!
I'm so happy, i even authorize you to donate to my project:
:D :D :D :D :D :D :D :D :D :D
