Arialia
I have download the SDK of imgtec for OpenGL ES 2 and i have a problem, i tested the binaries of examples but i only see very primitives things no texture and no other effects
with the SDK for OpenGL ES 1.1 everythings works fine
here a quote of my post under forum of imgtec :
QUOTE
just download your SDK to begin developp for Pandora
also i wanted to use the Opengl ES 2 SDK but i have a big problem
i tried binaries but all i seen is primitives things : colours, triangle or rectangle but no texture , text, and other ...Cry
so i tried same but with SDK OpenGL ES 1.1, and all binaries works fine Wink
My configuration : laptop Toshiba Satellite under XP
graphic card inside : ATI RADEON XPRESS 200M OpenGL 2.1 full
for example for the Alpha blend i see only three rectangle blue ... Confused
please help i need to see result program OpenGL ES 2 on my PC .... Pandora is not release yet : http://openpandora.org/ Wink
If you works with it can you tell us if you have same problem like me or not?
QUOTE
