I've seen posts talking about Pandora having power management features in the SoC and video chip, but I'm wondering how this will map out to the user:
Will Pandora support hibernating? If so, will it support the hibernation file(s) being located on the SD card rather than the internal flash?
Will the power switch be a hard power switch or a soft power switch? If soft, what will its behavior be and will its behavior be configurable? Will it have a way to force a power off in case things are locked up?
Can software detect if the clamshell is opened or closed? If so, will that be tied into the power management?
Thanks,
Pete
Thanks,
Pete
