hepcat
I’m having trouble getting my Pandora up and running. (I bought it a while ago, but I’m just starting to tinker with it now because of a long plane trip coming up next month.)
My goals for the Pandora are quite modest. I just want to be able to play music/video files, and Mame using PanMame or whatever Mame build works best on Pandora.
What I’ve done so far:
--I have read the User Manual and Quick start guide in their entirety. This includes following all the steps under the “First Time Use” heading and completing the First Boot wizard.
--I formatted an SD card on my PC (32 GB SanDisk SDHC), and created the directory structure suggested under the “Applications” heading. I then downloaded PND manager, Firefox, and PanMame and I think I put them in the correct folders, but they did not show up on the app list in either the Mini Menu or Xfce when I put the SD card in the Pandora. I rebooted and the apps still did not appear.
--I was initially able to get wireless working by following the instructions in the “Wi-Fi Wireless” heading of the Quickstart menu. I reformatted the SD card and had the Pandora create the directory structure for me on the SD card. However, even though the Pandora said I had a wireless connection, I was unable to download any PNDs from OpenPandora Repo. (I think it said Error 13, permission denied or something like that…)
--Next I decided to update the Pandora firmware since it has been over a year since I got the Pandora and I figured it must have been updated. The update started and took over an hour. I was pretty sure it finished, but now I think I may have interrupted it because Wi-Fi no longer works. (Initially I was able to turn on wifi by going to system àtoggle wifi and entering my password, but now the toggle wifi option seems to have disappeared from the system menu and I can’t get it to work any other way…)
If it matters, the Pandora currently says "Kernel 3.2" and "SuperZaxxon 1.71" on the boot up screen.
Yeah…I’m lost. Can anyone help?
