I put the fba cache in c\temp and games in c\temp\roms, but when I run the command line prompt I get an error. It opens the zipped rom but It says not found all the way down the list and 0 bytes at the bottom.
am I doing something wrong, do I really need to make a cache file for the games to work?
also should I unzip the rom first than run the exe?
any help would be great
thanks
thanks
