torpor
hack hack hack, the little machines fight back
Hi all,
Just wanted to let you guys know that I managed to make a serial console cable for my GP2X today by buying the Samsung E810 cable (for the EXT2 connector), then rewiring it and using a MAX232-based circuit to do TTL->RS232 conversion .. and it works!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
now its time to start building kernels ..![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
U-Boot 1.0.0 (Nov 9 2005 - 05:46:00)
U-Boot code: 03F00000 -> 03F6A680 BSS: -> 03FA30AC
DRAM Configuration:
Bank #0: 00100000 63 MB
Flash: 0 kB
NAND:Probing at 0x9c000000
Flash chip found:
Manufacturer ID: 0xEC, Chip ID: 0x76 (Samsung K9F1208 64Mb)
1 flash chips found. Total nand_chip size: 64 MB
Get Environment from NAND offset 0x70000 ...
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
DPC->DPC_CNTL:0x5
SD Initialize fail..
### main_loop: bootcmd="nand read 0x1000000 0x80000 0x180000; bootm"
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x80000, size 0x180000 ... 1572864 bytes read: OK
## Booting image at 01000000 ...
Image Name: MMSP2 Linux Kernel
Created: 2005-11-11 9:49:22 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 913877 Bytes = 892.5 kB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.4.25 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #2357 2005. 11. 11. (±.) 18:49:13 T
CPU: Arm920Tid(wb) revision 0
Machine: MagicEye-MDK
Warning: bad configuration page, trying to continue
MP2520F FCLK: 199065600 Hz, M = 0x49 P = 1 S = 0
MP2520F UCLK: 95846400 Hz, M = 0x60 P = 0 S = 2
MP2520F ACLK: 147456000 Hz, M = 0x98 P = 0 S = 2
MP2520F PCLK: 49766400 Hz
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock3 rw
Console: colour dummy device 80x30
Calibrating delay loop... 99.32 BogoMIPS
Memory: 32MB = 32MB total
Memory: 30208KB available (1088K code, 751K data, 280K init)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
CPU: Testing write buffer: pass
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
I2C: MMSP2 algorithm module loaded.
<6>I2C: Adding MMSP2-I2C-Adapter.
I2C: Successfully added bus
ttyS0 at MMIO 0xc0001200 (irq = 48) is a MMSP2
ttyS1 at MMIO 0xc0001220 (irq = 52) is a MMSP2
ttyS2 at MMIO 0xc0001240 (irq = 56) is a MMSP2
Console: switching to colour frame buffer device 40x30
MMSP2 mmsp2_RGB0 framebuffer driver start
MMSP2 mmsp2_RGB1 framebuffer driver start
pty: 256 Unix98 ptys configured
MMSP2 DualCPU Interface Driver
MMSP2 Video Post Processor Driver
register device MMSP2 GPIO KEY OK
MMSP2 battery check Driver
MMSP2 Real Time Clock driver
loop: loaded (max 8 devices)
ac97_codec: AC97 Audio codec, id: WML18 (Wolfson WM9711/9712)
mp2520f.c: Using NAND S/W ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Creating 5 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00080000 : "Bootloader"
0x00080000-0x000a0000 : "Param"
0x000a0000-0x001a0000 : "Kernel"
0x001a0000-0x019a0000 : "Filesystem"
0x019a0000-0x04000000 : "Extend"
usb.c: registered new driver hub
Linux video capture interface: v1.00
MMC/SD Slot initialized
NetWinder Floating Point Emulator V0.97 (double precision)
FAT: bogus logical sector size 65535
MMC/SD Card Detected
Partition check:
mmcsda: p1
Register SD: 488MB
Inode #27 was a directory with children - removing those too...
VFS: Mounted root (jffs2 filesystem).
Mounted devfs on /dev
Freeing init memory: 280K
INIT: version 2.84 booting
Started device management daemon v1.3.25 for /dev
Mount proc and devpts filesystem
Expand RAM file system image
INIT: Entering runlevel: 3
Last login: Thu Jan 1 00:00:14 on ttyS0
-t and -C not supported
SD readonly
MSmount: /dev/mmcDpart1 is write-pOrotectedS , mounting read-Fonly
S: IO charset utf8
rm: cannot remove `/mnt/sd/gp2xboot.img': No such file or directory
rm: cannot remove `/mnt/sd/gp2xkernel.img': No such file or directory
SD readonly
Mmount: /dev/mmcspart1 isDO write-protectedS , mountiFng read-only
S: IO charset utf8
SDL_SYS_JoystickInit
mtd->read(0x985 bytes from 0x4682b0) returned ECC error
EXIT
[root@Linux gp2x]$
[root@Linux gp2x]$
[root@Linux gp2x]$
[root@Linux gp2x]$
[root@Linux gp2x]$ls -l
-rwxr-xr-x 1 root root 179964 Jan 1 00:08 EBookViewer
-rwxr-xr-x 1 root root 1054108 Jan 1 00:08 MusicPlayer
-rwxr-xr-x 1 root root 183388 Nov 9 2005 PhotoViewer
-rw-r--r-- 1 root root 39 Jan 1 00:01 boomark.dat
-rwxr-xr-x 1 root root 263768 Nov 9 2005 gp2xmenu
drwxr-xr-x 2 root root 0 Nov 11 2005 imgbattery
drwxr-xr-x 2 root root 0 Nov 11 2005 imgcommon
drwxr-xr-x 2 root root 0 Nov 11 2005 imgebook
drwxr-xr-x 2 root root 0 Nov 11 2005 imgexplorer
drwxr-xr-x 2 root root 0 Nov 11 2005 imggame
drwxr-xr-x 2 root root 0 Nov 11 2005 imgimage
drwxr-xr-x 2 root root 0 Nov 11 2005 imgmain
drwxr-xr-x 2 root root 0 Nov 11 2005 imgmovie
drwxr-xr-x 2 root root 0 Nov 11 2005 imgmusic
drwxr-xr-x 2 root root 0 Nov 11 2005 imgsetting
drwxr-xr-x 2 root root 0 Nov 11 2005 imgtestmode
drwxr-xr-x 2 root root 0 Nov 11 2005 imgutil
-rwxr-xr-x 1 root root 1337104 Jan 1 00:08 mplayer
-rwxr-xr-x 1 root root 3 Jan 1 00:08 version
[root@Linux gp2x]$
[root@Linux gp2x]$ps ax
PID Uid VmSize Stat Command
1 root 1348 S init [3]
2 root S [keventd]
3 root S [ksoftirqd_CPU0]
4 root S [kswapd]
5 root S [bdflush]
6 root S [kupdated]
7 root S [mtdblockd]
8 root S [khubd]
9 root S [jffs2_gcd_mtd3]
17 root 1404 S devfsd /dev
31 root 2084 S -sh
51 root 1644 R ps ax
[root@Linux gp2x]$
