Hi have a installed gngeo2x and have rage2x as a front end. WOW what a system, show the power of the GP2X....Only one problem I cant get sound can anyone help me please...
I had to turn sound on in the config file that came somewhere with the emu all you do is open it with notepad or somthing similar and change the "sound faulse" to "sound true".
Again, in Rage2x press select. This time select cpu speed and change it by moving the stick left or right. Overclock as much as needed for smooth gameplay, if the emulator freezes just turn your GP2x of and on and lower the cpu speed a bit.
Check all the available options in Rage2x while you are changing the cpu speed. Most settings are pretty straightforward
