alterdimension
has anyone seen or heard of that 11 hour battery that was first out in spain. I wonder when it will arrive to be for purchase everywhere.
Well, obviously you've at least heard about it .. how's about a link?alterdimension said:has anyone seen or heard of that 11 hour battery that was first out in spain. I wonder when it will arrive to be for purchase everywhere.
In fact it's a mod of the PSP Thunder Power Pack, with an addon piece that makes it fit in the GP2X battery slot.alterdimension said:has anyone seen or heard of that 11 hour battery that was first out in spain. I wonder when it will arrive to be for purchase everywhere.
TelcoLou said:Well, obviously you've at least heard about it .. how's about a link?alterdimension said:has anyone seen or heard of that 11 hour battery that was first out in spain. I wonder when it will arrive to be for purchase everywhere.
http://www.play-asia.com/paOS-13-71-bg-77-...7u.html#related
I don't know if its compatible with gp2x. See if you can find out if it works with gp2x
Hope to be useful...http://www.hardcore-gamer.net said:GP2X 3600mAh Battery Specifications:
- Built using two Thunder Power Pack 5in1 and adapted for it's use on the GP2X.
- Perfectly fits the console, as it keeps located over the battery slot.
- It's an ideal stand to watch films on your GP2X, as the console sits over the battery.
- It's charged using any USB port (USB cable included, 24 hours charge time) or using a PSP battery charger (12 hours charge time).
Weight: 151gr.
Size: 5,5cm x 7cm x 2cm.
Voltage: 3,6v
Electric Charge: 3600mAh.
Duration:
11+ hours at 200 Mhz.
9+ hours at 275 Mhz.
Yep, but I added a single AA to the back of mine (inline with the 2 already in the tray, the battery clip on one end of the tray pops out so the third can be wired inline).reaper79 said:The words "giant, huge, clunky, expensive, and hideous" come to mind. I'd rather just carry extra batteries. I've seen this before when it first was talked about. If anything I want my handhelds to be smaller, not larger.
Reap
BenScar said:mrsnature, your batteries are in series, which means the "pack" is still 2700mAh, but with double the voltage (in this case 2*1.2v).
As you say, I just carry extra batteries with me.
That or use my "home made" stand (pics to be posted soon )
