Showdown between 2 small USB DBV's:
Device 1: ITE 9135 (10 euro)
New USB device found, idVendor=048d, idProduct=9135
[113007.244770] usb 4-1.1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[113007.246336] usb 4-1.1.3: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
[113007.246775] usb 4-1.1.3: dvb_usb_v2: found a 'ITE 9135 Generic' in cold state
[113007.246808] usb 4-1.1.3: firmware: direct-loading firmware dvb-usb-it9135-02.fw
picture of the device
Device 2: Realtek RTL2832U (12 euro)
[113856.430489] usb 4-1.1.3: New USB device found, idVendor=0bda, idProduct=2838
[113856.430494] usb 4-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[113856.430496] usb 4-1.1.3: Product: RTL2838UHIDIR
[113856.430499] usb 4-1.1.3: Manufacturer: Realtek
for details about setup, see the wiki or this older article
Quick comparison. VLC, with TV (same channel, minimized to see Pandora System Info). screen at 75% intensity.
device 1 drain: -3780 mW
device 2 drain: -2880 mW
This also confirms me why the first device seems to get much hotter (too hot actually, it heats up the pandora too).
Both devices also has a click when changing from one to another channel, however, they do not have it on my Linux desktop, so it might be firmware/driver related. (also, I've upgraded the Pandora OS sinds the previous test)
quality is similar (although you have to look on a bigger screen to see any artifacts (for example, on the Pandora, you do not need to enable de-interlacing)). I might see more artifacts on the first device, but I am not sure. Audio is the same (is being streamed as MP3 at 160kbps)
Antenna on both are smaller than my previous device (1 cm). Also had to copy over the firmware for the ITE9135
winner: Realtek.
However, the Realtek at minimal brightness, -660mA in total, versus -638mA for the Velleman
dvb_usb_af9035 so... yeah...
tl;dl: both work., one uses 1000mW more than the other!
winner: Realtek.
