Shikaku
ROFL THE WORD PENIS IS HILARIOUS!
Q: Does my battery charger charge fully?
A: Depends on your batteries and your charger of course, but here's how you can tell:
Take the amount of time it takes to charge.
Multiply it by the Current it gives the batteries. If you don't know what to look for, here's an example (from my energizer 8.5 hour cheap $10 charger).
Mine says in the Output: 360mAx2. That means it gives 2 360mA per hour for each connection.
To get the mAh, just multiply it:
so I would get 3060mAh for each charge on the battery for my charger, because it gives 360mA in 8.5 hours.
Now look at your battery rating. If it matches or is higher, it usually charges it fully =)
Note: intelligent chargers know when to stop anyway, this is just for chargers that charge ONLY time based...
