levi
Still fresh, damnit!
I want to know where you parked your time machine that got you instantly here from 1996.ricing my gentoo
I understand that a LiPo battery will give us better battery life than AAs, but I have to call you out on this one. I never had less than a 3 hour battery life with the GP2X, even on shitty AAs.However, alkalines have a big problem, they're very load sensitive. A heavy load will kill the effective capacity. This is why they wouldn't even last an hour on GP2X.
AA is not synonymous with alkaline, which is what I referred to. Many different technologies can be found in AA form factor. Even Lithium. You were probably using NiCD or NiMH if you got 3 hours.I understand that a LiPo battery will give us better battery life than AAs, but I have to call you out on this one. I never had less than a 3 hour battery life with the GP2X, even on shitty AAs.
That's why I specifically mentioned "shitty" batteries. I had rechargeables that I normally used. But every once in a while, I needed to fork out for some cheap duracell or energizer alkalines due to my rechargeables dying on me while I was out. I never got less than 3 hours with those. My rechargeables normally got me 5 hours.AA is not synonymous with alkaline, which is what I referred to. Many different technologies can be found in AA form factor. Even Lithium. You were probably using NiCD or NiMH if you got 3 hours.I understand that a LiPo battery will give us better battery life than AAs, but I have to call you out on this one. I never had less than a 3 hour battery life with the GP2X, even on shitty AAs.
Terrible battery life on alkaline was a well known problem on GP2X, see here:
http://wiki.gp2x.org/articles/g/p/2/GP2X_Issues.html#Life_of_Batteries_that_come_with_the_GP2X
In the garage. Why?I want to know where you parked your time machine that got you instantly here from 1996.ricing my gentoo
Do they have micro-USB phone chargers? Most probably. Just get one of those. Problem solvedI dont really know what size Pyras battery will be, and never had a pandora, but still, listen up:
Maybe we should make a "Dummy DC-DC battery" which accepts AA (AAA if the battery is small) inside?
What do you do when you battery runs out of power? See any electricity sockets? NO.
See any shops? Yes. Do they got batteries? Most probably.
Having vastly reduced capacity under heavy load is a well known problem with Alkaline. I think very few alkalines would get 3 hours in a condition where high end NiMH would get 5 hours on GP2X. http://www.powerstream.com/AA-tests.htmThat's why I specifically mentioned "shitty" batteries. I had rechargeables that I normally used. But every once in a while, I needed to fork out for some cheap duracell or energizer alkalines due to my rechargeables dying on me while I was out. I never got less than 3 hours with those. My rechargeables normally got me 5 hours.
I wonder.. with 2500mAh NiMH you generally don't even get 4.5 hours.. http://www.gp32x.de/board/index.php?/topic/29240-battery-life-on-gp2x/My NiMHs might've lasted for longer than 5 hours. I never really timed those ones, I just remembered that they lasted a full car trip on a trip that I knew to take ~5-5.5 hours. Also, I had a whole bag of them, so I'm not sure that any pair of NiMHs I ever inserted were actually at full charge.
-God Ginrai
My NiMHs were 3000mAh Energizers, IIRC.I wonder.. with 2500mAh NiMH you generally don't even get 4.5 hours.. http://www.gp32x.de/board/index.php?/topic/29240-battery-life-on-gp2x/My NiMHs might've lasted for longer than 5 hours. I never really timed those ones, I just remembered that they lasted a full car trip on a trip that I knew to take ~5-5.5 hours. Also, I had a whole bag of them, so I'm not sure that any pair of NiMHs I ever inserted were actually at full charge.
-God Ginrai
You could do better with higher capacity, but I was using that as a baseline.
