when i want to save my AVI (on Virtual Dub) there comes an error "Error initializing audio stream compression:The requested conversion is not possible."
need help!
I think its because your AVI file is in 48KHz (or 24...12...) instead of 44.1,22.05...
The best for GP32 is (I think) 11.025 16bits mono (stereo if you really want something good) @16kbits/s
this provides a "good" sound for a very small size B)
You should use dbpoweramp (or another soft) to convert you WAV file from 48... to 44.1
good luck
see you
