Okay. I've had bad experiences with Adata SD cards. I got a 2GB brand new off Ebay, used it for a month or two, then had insane errors of it randomly failing to write. I got in touch with Adata support, and they presumably replaced the card (or maybe reformatted it, I don't know). It worked for a while, but then under Linux I got these write fails due to a sector not being there. Now just recently after using about 697MB I got this message saying "Cannot find the sector requested".
Now, this naturally makes me very pissed. When I had run scandisk or defrag in the past it would make my SD card go to 1gb from 2gb. I don't know if this is only the "good" sectors, or if it just doesn't like my card.
Anyway, I think I'll buy an SD card. The 4GB 150x Adata cards look like a steal (aren't they like $90 on ZZF?).
But I want a good card reader to go with it. My current one doesn't like >1GB cards, and using the GP2X isn't really the best way, I've found. My OS is Windows XP Pro SP2 so compatibility shouldn't be much of an issue compared to Gentoo Linux which I was using in the past for quite a while...
Thanks.
Thanks.
