Problem With Gp Cinema
This is me shouting in the dark, but have you attempted to overclock a bit by pressing R?
nope
If you mean Nope, I haven't tried, then do so.
If you mean Nope, that doesn't work, then I am sorry, but that was just a wild guess by reading older GP Cinema problems.
I left it on default and tried to open it, no good. I tried to change it (make it lower and higher) no good either.
Hmm. And you encoded it propery?
Could you give me, us, a rundown on what you did overall, from beginning to finish?
I mean from DVD to file, or from file to smaller file... whatever.
Is there definately sound on your clip? It will not play clips that do not have sound and will just sit there like a lemon showing you all of the stats fo the clip. (I spent ages pondering this before realising) I just added blank sound to the clips i had.
I just took a small file from my computer and re-encoded it usingthis
I tested it using virtual dub and there is sound. Though the problem sounds similar ( I have stats but cannot open the file).
Me have the same Problem.
I testet with MP3 sound @ 56 and 64 kb
Viedeo 320x240 @ Xvid and DivX.
The GP Cinema shows the properitis right (file length ...)
But it doesn't start to play the Movie :-/
cu
