Problem Loading Firmware 1.4?
Eagle747
I loaded firmware 1.4 (upgraded from 1.1) which appeared to go OK. The green loading screen reports 1.4 byt the info screen from the setup option reports 1.1.
Does this mean my firmware upgrade didn't work properly? I'm using the Gorilla skin. Tried to re-install the default skin but couldn't get it to load....
FFNoir posted on Feb 28 2006 at 12:11 PM said:
did you run the .gpu files that came with it?
No - duh - I forgot! OK now - but still can't load the default skin. Doesn't matter - now it's reporting 1.4.0! 1 out of 10 for concentration! Thanks.
