So I know there is a thread about charging over USB but things were a bit confusing in it
First off, everyone keeps referring to weather it will just be able to run without draining the battery on just USB, calculating the amount of mAh that the Pandora draws (estimated 400mA) vs the max (spec) USB output (500mA). However, I didn't see any mention of what voltage the Pandora's battery is running at, I know USB is at 5V.
Basically, the number I'm looking for is the total mWh, since that's a better way to look at power consumption/supply. I wanted to see how long this could power it/charge it for:
http://www.ladyada.net/make/mintyboost/
or any similar device
