Need Help Using Mikmod
kevin
Netherlands
Hi,
I've tried using the mikmod sound library directly (without SDL), and even linking the libmikmod library file hangs the device. Does it need additional libraries/compiler options?
We're using the libraries from theoddbot at wiki.gp2x.com
Maybe someone can post a working example (preferably with a compiled .gpe program)?
This is our current compile script:
@set OLDPATH=%PATH%
@set PATH=%PATH%;C:\_Build\devkitGP2X\bin;C:\_Build\devkitGP2X\arm-linux\bin
arm-linux-g++ -I "." -D__GP2X__ -c helloworld.cpp -o helloworld.o
arm-linux-g++ helloworld.o -ldl -lmikmod -o helloworld.gpe
@set PATH=%OLDPATH%
Alright, linking the library seem to work correctly now (we're able to play wav files successfully). To get it to work we've removed some of the library files, only libmikmod.a will be linked.
The only problems that are left is that calling MikMod_RegisterLoader(&load_mod) will hang the device. Also there is a delay (around 2 seconds) before a sound will play. Any clues?
