Need Help: Problem With Variable Arrays In Classes
Maybe
for (int i=0;i<3;i++) SDL_BlitSurface(myLevel.BG1.BG_gfx, &myLevel.BG1.Frame, screen, myLevel.BG1.Pos);
instead of
for (int i=0;i<3;i++) SDL_BlitSurface(myLevel.BG1.BG_gfx, &myLevel.BG1.Frame, screen, &myLevel.BG1.Pos);
Which will give you contents of Pos, instead of the address of pos?
I don't SDL, so I don't know the parameters. The line just seems strange when your allocating a pointer, and then taking the address of it. Maybe I've got the wrong stick...
Side note, you have a memory leak in the class of BG (not freeing allocated memory). Consider using std::vector instead.
I can't see anything distinctly wrong with the code. Can you provide a screenshot of the result that you are currently getting?
You're declaring a member variable BG1 in level
CODE
class Level{
public:
BG BG1;
Level(void);
The a local variable in Level's constructor, so you're not initilising the member variable:
CODE
Level::Level(void){
BG BG1(3);
What you really want is :
CODE
class Level{
public:
BG *BG1;
Level(void);
Level::Level(void){
BG1 = new BG(3);
or add a separate method
CODE
BG::setInstances(int instances){
Pos = new SDL_Rect[instances];
class Level{
public:
BG BG1;
Level(void);
Level::Level(void){
BG1.setInstances(3);
Edit:
or by initialiser list
CODE
class Level{
public:
BG BG1;
Level(void);
Level::Level(void) : BG1(3) {
Good spot Parkydr.
To prevent this problem in the future, look at the use of the 'explicit' keyword.
CODE
class BG{
public:
explicit BG (int);
void imgload(char *path);
SDL_Surface *BG_gfx;
SDL_Rect *Pos;
SDL_Rect Frame;
Again, I recommend using std::vector over the allocating the array yourself.
