Need A Little Help Setting Up
Dimension
Hi everyone I just downloaded the devkit and looked over some docuentation but as im not as much of a windows user as I used to be I need a litle bit of help. It said in the readme to add path to the binary files I had no problem getting to the menu to change it in control panel but Im not exactly sure where I should put the entry as theres a few menu's and the best bet looks like envoironment variables. By the way im using XP. Sorry if this sounds noobish,lol.
I assume you're setting it up so you can run gcc from the command line, etc... in which case, you probably want to add the location(s) to the PATH= environment variable.
