Missing Pandora Icon after using USB monitor
RMJ250
Hi all,
Having used an external usb monitor through a Displaylink adapter, after reseting the Pandora Icon and the battery percent have disappeared, is there a way to reset this?
Thanks,
J
Just add them back. Right-click the panel and choose Add New Items...
Actually that was badly worded, the start menu button and battery icon were there but instead of the cute Pandora symbol it said xfce-menu and the battery level just had no percentage next to it. Nevermind worked it out, right-click on the start menu button/properties, change the icon to Pandora and remove the xfce-menu text from the box and right-click on battery level and tick the percentage box. Thanks for the quick response though!
J
