Kumaki
Well-Known Member
Thanks.Okay, I've just tried out VICE on my machine, and it seems that the Start button opens the menu - can't really call it a GUI, but it's where you can change settings, discs, and quit the emulator from.
I will try that.
Incidentally, I solved NeoEmu...my neogeo.zip file was out of date.
I am going to re-try neopop with that now, too, currently I have RACE on there...but I think neopop might work with the newer neogeo.zip file.
Nope. The Start button did not work for me on VICE.
This is the button that says Start and Alt on it, right?
I pressed it...no soap
So I tried Shift + that button...no soap
Then I tried Function and that button...no soap
Then I tried That button plus the Left Shouldr button, also tried the right shoulder button, and then both together....all no soap.
So I still can't figure getting into the GUI on VICE. I ended up having to kill the process by holfing the Pandora button.
