Hey friends! Yesterday I was hacking away at a script on my pandora but forgot to connect the power supply. The pandora died on me while I was working. I booted with power supply connected and continued working. when I was ready to package my script as a pnd, I noticed my scripts had reset to an earlier state. I tried to run fsck on the card in my laptop and got the following message:
"Unable to set superblock flags"
so I looked up the backup superblocks and tried again with two different backup points. The scard seems to be severely damaged. nothing changed after remounting, it's a 128gb class 10 card by platinum formatted to ext4 btw.
I was able to get all my data off the card. Then I tried reformatting with gparted but it won't even delete the partition, always throwing me the same errors.
Does anyone have an idea what I should try next? I guess it's physical damage.
Anyone able to recommend a decent brand 128gb sdxc which won't make me poor? I am in europe, germany.
thanks!
thanks!
