PowerGod
Forum Addict!
- Joined
- Jun 20, 2011
- Messages
- 4,673
As a little update, my new HD is now working with Windows... and the funny thing is, that this vanilla installation on a vanilla HD has Windows Update not working... and seems like this is the rule as I read on many forums...
After trying all the official "fixing tools" both integrated and downloaded from Microsoft, DISM to check my windows image, SFC and also manual hacking of services and registry entries, I still obtained nothing...
My only hope was to update manually the "Windows Update" with a patch to be downloaded manually from the Microsoft site... but all the links to the file are 404...
So, my last choice will be to use a third party program called "WSUS Offline Update", but this is another story...
I tried to put the new HD with the vanilla installation in the USB box, and I have to confirm that its partitions are invisible too
I then put the faulty HD in the USB box to read it directly from Windows, and here the cool stuff: instead of seeing it as unpartitioned (like linux does), it tells that there is only one partition (that cover the full disk size) called "GPT protected partition" (roughly translated)...
Now, I could be wrong, but this seems to me some kind of deliberate way to bound a disk to a specific hardware...
Anyway, thanks to linux I was able to recover all the files I wanted from the disk, but there's one important thing missing... the last passwords that I saved only on the browser (I always backup those at intervals, but there are too many accounts around to be always up to date)... and those are recoverable only by using the exact same user...
So my last adventure will be to try a Windows restore on the faulty HD (now I can create all the installing supports that i want !!
)... so, if i'm lucky, and I can start that Windows for one last time, I could export all my passwords...
Then I will be totally happy !! Because as of now, except for those passwords, I lost nothing !!
(I had anyway to juggle a lot with all my external supports to find the space to put all the stuff... I also had to store some of the files in the Pandora too... and had to delete all my re-downloadable games, like TBs of stuff... if I just think about how much time required to download them the first time
It could, and that would be annoying, but the issues with the old drive might just be because it's not working properly.
