Grench
Forum Addict!
- Joined
- Oct 3, 2008
- Messages
- 6,629
I realize that F2FS is the latest darling disk format of the Linux world. However, living on this bleeding edge has some pretty serious limitations and drawbacks.
Installing the latest available-to-me OS image onto a 64GB SDXC card results in only being able to use/see the first 8GB of the card within the OS. Where we're using apt from Debian repositories for software installs, more space in the rootfs would be a good thing. I can foresee users installing to up to 1TB cards.
Where the frustration hits: Trying to resize or grow the F2FS partition to 'fill the card'. Yes, I figured out how to do it by soft deleting the partition, creating a new bigger partition, formatting to F2FS then accepting back in the original signature then migrating the F2FS. It is a completely hacky multiple tools needed command line mash of frustration. F2FS is not compatible yet with most of the mainline partition management tools - and it has been a couple of years. F2FS still feels like betaware. There are -no- tools available to shrink an F2FS to spin off to archive.
If the partition were EXT4, it would simple to copy / expand / grow / shrink the partition and could be done with a wide array of GUI based tools.
So - what is the underlying reason we're using F2FS instead of EXT4? Using F2FS removes flexibility and compatibility and feels like way more trouble than it is worth.
