Dingoo Will Not Load Flasher Script After Nand Write
HydraLancer
Atlanta GA, USA
Hello
I am basically trying to flash the NAND for a friend's Dingoo, I am using the rather obnoxious "Idiot's guide" to try to flash the NAND, and everything goes good, until the part where it says the Dingoo is supposed to magically come back to life after the NAND write. This is after the second and last usbtool command line, and the flash options are supposed to appear on the Dingoo screen.
I have followed everything as far as I can see, but I don't know why the screen is not coming on,
The Dingoo reboots just fine into the normal firmware, but no Dual Boot Dingux yet
Help would be much appreciated
Thank you.
darfgarf
Well-Known Member
Blighty
www.gfrancisdev.co.uk
write it twice :p
or at least that's what my old one used to need doing, other than that, search the dingoonity forum, pretty much every problem has been solved before
zear_
This is a common problem and there's a fix for it: http://boards.dingoonity.org/dingoonity-news/hwinit_2-for-dingux-installer-859
