Can I Charge My Caanoo And Wiz With The Same Usb Cable?
difuno
I have a Wiz and just got my Caanoo. The USB cables of the two look the same. But I did a search on google and someone said that they are different.
My question is, can I charge the Wiz and Caanoo with the same cable (Wiz's or Caanoo's)?
Thanks in advance!
of course, I use my old WIZ cable for my Caanoo too, it works perfectly both for charging and data transfer
I just tested, and yes you can. They appear to be the exact same cable.
No Wiz and Caanoo charging cable are not interchangeable even though they look and fit the same. I have both. They can transfer data using either cables though.
