Hi all,
I did a brief search through these forums to see if I could find a thread similar to this one and I didn't see anything that looked remotely close (to clarify that I do not intend to "repost" or what-have-you)
Okay.... the problem was a common one: running a high quality Wifi USB dongle on the GP2X.
I bought the EXT/USB cable from ARTaylor.... measured the output at 3.3v from my GP2X. So I made a small circuit using one resistor, one diode, 1x USB Type A female socket, 1x USB Type B female socket and 1x 4xAAA battery holder (along with a pack of 4 2500mAh Energizer batteries).
Got a little over 5.1v which is ample, and I made it measure (With the addition of a few more components) to output a stable usable 500mA. This means that even the most power-consuming USB devices can run on it, including those Host-Powered USB hubs.
I feel that a little more work and I could make some 4 port 500mA hubs ready for selling (just to cover costs) if anyone is interested?
The tests I performed are:
1) Will it power and run a USB Optical Mouse (YES)
2) Will it power and run a Wifi dongle (YES)
3) Will it power and run a laptop external hard drive (YES.... AND THAT'S MY FAVORITE PART!!!)
4) How long will it power my USB Controlled LED mood lamp (5 hours at full draw)
If anyone is interested, I just want it to be known. Or if you have any other ideas/problems/suggestions that would be great too!
When my stupid Digicam comes back from the shop (being repaired AGAIN) I will take some snapshots of the thing running in various situations.
I'm really hyped up though because now I can take 160GB of music/movies/games etc. with me wherever I go and use them on my GP2X.... and everything fits in just one pocket (excluding the GP2X itself of course).
Finally I'd just like to say I'm not plugging my wares in here or anything! I just wanted to make sure y'all are aware this is possible..... and if you would like I can post a detailed diagram + intructions of how I made it work, and how to make your own of course.
That's all for now and I'm off to bed.
Regards,
Simon J Stuart
Regards,
Simon J Stuart
