coldfish
- Joined
- Dec 20, 2006
- Messages
- 320
The battery LED indicator has never worked on my MK2 (fw 2.0.0). Ive tested it with Vice and the BattLED test program, no luck.
I heard somewhere, that some GP2X's have the LED soldered in reverse polarity, strange!
Today, I opened mine up and sure enough it was reversed, and broken too, (LED resin case cracked).
Its easy to tell, as the (working) power LED is correctly aligned with the (-) terminal to the right (viewing circuit board from battery side) same as marked on the board, my batt LED wasnt.
So after much fiddling I managed to replace it with a slightly modded 3mm high brigtness LED.
Its nice to finally have some warning before my AA's die.
BTW the GP2X is a real biatch to reassemble!
The situation does leave me wondering, how such a simple manufacturing error could occur?
Anyone else have this problem?
